= Мир MS Excel/Файл распух до нелогичных размеров. - Мир MS Excel
  • Страница 1 из 5
  • 4
  • 5
KuklP Дата: Пятница, 10.09.2010, 15:35 | Сообщение № 1
Репутация: 486 ±
Сразу оговорюсь - макросы не мои. Я только чуточку доработал их для большей универсальности. Итак:
Code
Option Explicit
Option Base 1
Sub ReduceSize()
Dim lAntR As Long
Dim iAntK As Integer
Dim aR() As Single
Dim aK() As Single
Dim n As Integer
Dim sFil1 As String
Dim sFil2 As String
Dim sKat As String
Dim sArk As String
Dim sh As Worksheet
Dim nWb As Workbook
Dim i As Integer
      i = 1
       sFil1 = ActiveWorkbook.Name
       sKat = ActiveWorkbook.Path
Set nWb = Workbooks.Add
       sFil2 = ActiveWorkbook.Name
Workbooks(sFil2).SaveAs sKat & "\" & "(2)" & sFil1
For Each sh In ThisWorkbook.Sheets
sh.Activate
sArk = ActiveSheet.Name
lAntR = Cells.Find(What:="*", SearchOrder:=xlByRows, SearchDirection:=xlPrevious).Row
iAntK = Cells.Find(What:="*", SearchOrder:=xlByColumns, SearchDirection:=xlPrevious).Column
ReDim aR(lAntR)
ReDim aK(iAntK)
For n = 1 To lAntR
      aR(n) = Rows(n).RowHeight
       Next n
        For n = 1 To iAntK
      aK(n) = Columns(n).ColumnWidth
       Next n
Range(Cells(1, 1), Cells(lAntR, iAntK)).Copy
      With nWb
        If .Sheets.Count < i Then
      .Sheets.Add after:=.Sheets(.Sheets.Count)
        .Sheets(i).Name = sArk
       .Sheets(i).Paste
For n = 1 To lAntR
.Sheets(i).Rows(n).RowHeight = aR(n)
Next n
For n = 1 To iAntK
.Sheets(i).Columns(n).ColumnWidth = aK(n)
Next n
i = i + 1
Call ExportAllStdModules(Workbooks(sFil2))
Workbooks(sFil1).Close savechanges:=True
Code
Private Sub ExportAllStdModules(wb As Workbook)
Dim iTempPath As String, iModuleName As String
Dim iVBComponent
With Application
.ScreenUpdating = False
iTempPath = .DefaultFilePath & .PathSeparator
With wb.VBProject.VBComponents
For Each iVBComponent In ThisWorkbook.VBProject.VBComponents
If iVBComponent.Type = 1 Then
iModuleName$ = iTempPath$ & iVBComponent.Name
iVBComponent.Export Filename:=iModuleName$
.Import Filename:=iModuleName$
Kill PathName:=iModuleName$
.ScreenUpdating = True
P.S. Думаю, излишним будет напоминать о резервном копировании данных (хотя макрос данные исходной книги никак не затрагивает).
СообщениеСразу оговорюсь - макросы не мои. Я только чуточку доработал их для большей универсальности. Итак:
Code
Option Explicit
Option Base 1
Sub ReduceSize()
Dim lAntR As Long
Dim aR() As Single
Dim aK() As Single
Dim n As Integer
Dim sFil1 As String
Dim sFil2 As String
Dim sKat As String
Dim sArk As String
Dim sh As Worksheet
Dim nWb As Workbook
Dim i As Integer
      i = 1
sh.Activate
ReDim aR(lAntR)
ReDim aK(iAntK)
For n = 1 To lAntR
       Next n
        For n = 1 To iAntK
       Next n
      With nWb
       .Sheets(i).Paste
For n = 1 To lAntR
Next n
For n = 1 To iAntK
Next n
i = i + 1
Code
Dim iVBComponent
With Application
Автор - KuklP
Дата добавления - 10.09.2010 в 15:35
Alex_ST Дата: Вторник, 01.02.2011, 18:58 | Сообщение № 2
Репутация: 622 ±
Код классный! Можно рекомендовать к широкому использованию.
Попробовал на работе с распухшим за несколько лет общим файлом с сотней страниц. Весил 40 метров. Открывался по сети "со скрипом". Теперь весит 12 метров и по сравнению со старым прямо летает.
Зная нелюбовь Сергея (KuklP) к оформительской работе, давно собирался "причесать" классный код, предложенный им: более понятно (на мой взгляд) переобозвать переменные, добавить комментарии с целью повышения его читабельности не слишком искушенными пользователями.
А тут заболел (грипп, зараза!), сижу дома. Подполировал код Сергея. Надеюсь, он не против?
И так:
1. В стандартный модуль разбухшей книги помещаем код:[vba]
Code
Option Explicit
Option Base 1
Sub ReduceSize() ' фитнесс для разбухших файлов
' Procedure : ReduceSize
' Author    : KuklP + Alex_ST ("полировка" и комментарии)
' URL       : http://www.excelworld.ru/forum/3-57-1
' Date      : 10.09.2010 + 01.02.2011
' Purpose   : фитнесс для разбухших файлов
       Dim LastRow&, LastColumn%
       Dim arrRowsHeight!(), arrColumnsWidth!()
       Dim oldWbName$, newWbName$
       Dim WbPath$, iShtName$
       Dim iSht As Worksheet
       Dim newWb As Workbook
       Dim i%, n%
       WbPath = ActiveWorkbook.Path ' запомним путь к книге
       oldWbName = ActiveWorkbook.Name ' запомним имя старой книги
       Set newWb = Workbooks.Add ' создадим новую книгу (она сразу станет ActiveWorkbook)
       ActiveWorkbook.SaveAs WbPath & "\" & "(NEW) " & oldWbName 'сохраним новую книгу рядом со старой с префиксом к имени "(NEW) "
       newWbName = ActiveWorkbook.Name ' запомним имя новой книги
       i = 1 ' начинаем с первой страницы новой книги
       For Each iSht In ThisWorkbook.Sheets ' цикл по всем листам старой(ThisWorkbook) книги
           iSht.Activate
           iShtName = ActiveSheet.Name
           LastRow = Cells.Find(What:="*", SearchOrder:=xlByRows, SearchDirection:=xlPrevious).Row ' последняя строка на листе, содержащая хоть какие-нибудь значения
           LastColumn = Cells.Find(What:="*", SearchOrder:=xlByColumns, SearchDirection:=xlPrevious).Column ' последний столбец на листе, содержащий хоть какие-нибудь значения
           ReDim arrRowsHeight(LastRow)
           ReDim arrColumnsWidth(LastColumn)
           For n = 1 To LastRow ' запомним высоты строк в массив
               arrRowsHeight(n) = Rows(n).RowHeight
           Next n
           For n = 1 To LastColumn ' запомним ширины столбцов в массив
               arrColumnsWidth(n) = Columns(n).ColumnWidth
           Next n
           Range(Cells(1, 1), Cells(LastRow, LastColumn)).Copy ' копируем только диапазон, содержащий данные
           With newWb
               If .Sheets.Count < i Then .Sheets.Add after:=.Sheets(.Sheets.Count)
               .Sheets(i).Name = iShtName
               .Sheets(i).Paste ' копируем на страницы новой книги диапазон, содержащий данные
               For n = 1 To LastRow ' восстановим высоты строк
                   .Sheets(i).Rows(n).RowHeight = arrRowsHeight(n)
               Next n
               For n = 1 To LastColumn ' восстановим ширины столбцов
                   .Sheets(i).Columns(n).ColumnWidth = arrColumnsWidth(n)
               Next n
           i = i + 1 ' продолжим на следующей странице новой книги
       Call ExportAllStdModules(Workbooks(newWbName)) ' скопировать все компоненты VBA в новую книгу
       Workbooks(newWbName).Save ' сохраним новую книгу
       Workbooks(oldWbName).Close SaveChanges:=False ' закроем старую книгу без сохранения изменений
Private Sub ExportAllStdModules(wb As Workbook) ' скопировать все компоненты VBA в новую книгу
       Dim iTempPath$, iModuleName$
       Dim iVBComponent
       With Application
2. Выполняем макрос ReduceSize
3. После выполнения работы макроса рядом с распухшим файлом будет создан такой же по содержанию, но "похудевший" новый файл с префиксом (NEW).
СообщениеКод классный! Можно рекомендовать к широкому использованию.
И так:
Code
Option Explicit
Option Base 1
       Dim i%, n%
           iSht.Activate
           Next n
           Next n
           With newWb
               Next n
               Next n
       Dim iVBComponent
       With Application
Дата добавления - 01.02.2011 в 18:58
KuklP Дата: Вторник, 01.02.2011, 19:28 | Сообщение № 3
Репутация: 486 ±
Quote (Alex_ST)
Привет, Леш. С чего бы я был против? Для того и выкладывал, чтоб все пользовались. И вообще, я не раз и на разных форумах выказывал свою нелюбовь к скрытию, запароливанию и т.д. То, что создано, должно работать и приносить пользу. И чем большую, тем лучше:-)
Выздоравливай, давай!
Сообщение отредактировал KuklP - Вторник, 01.02.2011, 19:32
Quote (Alex_ST)
Автор - KuklP
Дата добавления - 01.02.2011 в 19:28
Alex_ST Дата: Вторник, 01.02.2011, 19:36 | Сообщение № 4
Репутация: 622 ±
Привет, Серёга!
Рад, что ты ответил. Всё-таки мнение автора - главное. Хотя я в общем-то в твоём "одобрямсе" и не сомневался. Но всё-таки...
Всё. Больше в теме на флудим. Обсуждение здесь - это правильно. А общение - флуд.
Сообщение отредактировал Alex_ST - Вторник, 01.02.2011, 19:38
СообщениеПривет, Серёга!
Дата добавления - 01.02.2011 в 19:36
KuklP Дата: Пятница, 18.02.2011, 10:27 | Сообщение № 5
Репутация: 486 ±
KuklP, Черт, в макросе досадная ошибка.
Вместо
With newWb
       If .Sheets.Count < i Then .Sheets.Add after:=.Sheets.Count
надо
With newWb
Подожду кого-нить из модеров, попрошу исправить, а то меня не пускает редактировать
Сообщение отредактировал KuklP - Пятница, 18.02.2011, 10:36
СообщениеKuklP, Черт, в макросе досадная ошибка.
Вместо
With newWb
надо
With newWb
Автор - KuklP
Дата добавления - 18.02.2011 в 10:27
Hugo Дата: Пятница, 18.02.2011, 11:09 | Сообщение № 6
Репутация: 797 ±
Исправил.
СообщениеИсправил.
Автор - Hugo
Дата добавления - 18.02.2011 в 11:09
KuklP Дата: Пятница, 18.02.2011, 11:22 | Сообщение № 7
Репутация: 486 ±
Спасибо, Игорь. Что бы я без тебя...:-)
СообщениеСпасибо, Игорь. Что бы я без тебя...:-)
Автор - KuklP
Дата добавления - 18.02.2011 в 11:22
Alex_ST Дата: Пятница, 18.02.2011, 15:40 | Сообщение № 8
Репутация: 622 ±
Я тоже наткнулся я на эти грабли, когда пытался чужой многостраничный файл "похудеть", но тогда просто закомментировал так:
If .Sheets.Count < i Then .Sheets.Add ' after:=.Sheets.Count
[/vba], т.к. было нужно срочно и был "завал" на работе. Решил разобраться потом и забыл... sad
А вот на днях на другие "грабли" напоролся: проблема с элементами OLEObject на листе - не переносятся, гады.
Правда, это было ближе к концу рабочего дня, а перегружать Ёксель я не пробовал (опять "завал")... И тоже отложил "разбор полётов". Может, перед выполнением макроса режим конструктора включить? Надо подуамть...
Сообщение отредактировал Alex_ST - Пятница, 18.02.2011, 15:43
СообщениеЯ тоже наткнулся я на эти грабли, когда пытался чужой многостраничный файл "похудеть", но тогда просто закомментировал так:
Дата добавления - 18.02.2011 в 15:40
KuklP Дата: Пятница, 18.02.2011, 23:59 | Сообщение № 9
Репутация: 486 ±
А еще он не перенесет макросы из модулей листов. Можно разрешить, но перенесет как классы. А OLEObject в новом файле сохранившие ссылки на старый файл тебе нужны? Отож. А если еще и куча форм в файле, грабли обеспечены. Я уже неоднократно утверждал, что универсальные макросы всех времен и народов - это не мое:-) Я больше на злобу дня...
СообщениеА еще он не перенесет макросы из модулей листов. Можно разрешить, но перенесет как классы. А OLEObject в новом файле сохранившие ссылки на старый файл тебе нужны? Отож. А если еще и куча форм в файле, грабли обеспечены. Я уже неоднократно утверждал, что универсальные макросы всех времен и народов - это не мое:-) Я больше на злобу дня...
Автор - KuklP
Дата добавления - 18.02.2011 в 23:59
Alex_ST Дата: Суббота, 19.02.2011, 18:52 | Сообщение № 10
Репутация: 622 ±
Quote (KuklP)
Я это тоже заметил, но разбираться было некогда - ручками перенёс вместе с OLEObject-ами листа.
Для меня это вообще наикрутейший облом, т.к. я как раз люблю писАть так, чтобы было как можно меньше связей между листами. При таком стиле программирования можно лист без проблем копировать в другую книгу и всё будет работать, как, например, в моём "удобном автофильтре" ... Конечно, это ведёт к избыточности кода, зато удобно.
Сообщение отредактировал Alex_ST - Суббота, 19.02.2011, 21:44
Quote (KuklP)
Дата добавления - 19.02.2011 в 18:52
Alex_ST Дата: Понедельник, 21.02.2011, 11:06 | Сообщение № 11
Репутация: 622 ±
Сергей, а почему собственно в Private Sub ExportAllStdModules ты ограничился только копированием стандартных модулей?
Если я правильно понял, то твой код
[/vba] это то же самое, что
If iVBComponent.Type = vbext_ct_StdModule Then
А почему нельзя копировать точно также и модули классов (Type = vbext_ct_ClassModule = 2), модули форм (Type = vbext_ct_MSForm = 3)?
К стати, а вот здесь написано:
vbext_ct_Document (100): One of the Sheet modules or the ThisWorkbook module
что-то я не понял, модули листов разве не модули класса?
СообщениеСергей, а почему собственно в Private Sub ExportAllStdModules ты ограничился только копированием стандартных модулей?
Дата добавления - 21.02.2011 в 11:06
KuklP Дата: Понедельник, 21.02.2011, 11:41 | Сообщение № 12
Репутация: 486 ±
См. ответ от Дата: Пятница, 18.02.2011, 23:59.
Закомментируй так и посмотри, что выйдет:
'If iVBComponent.Type = 1 Then
'End If
Сообщение отредактировал KuklP - Понедельник, 21.02.2011, 11:44
СообщениеСм. ответ от Дата: Пятница, 18.02.2011, 23:59.
'End If
Автор - KuklP
Дата добавления - 21.02.2011 в 11:41
KuklP Дата: Понедельник, 21.02.2011, 12:42 | Сообщение № 13
Репутация: 486 ±
Вымучил, так работает:
Sub ReduceSize()
      Dim lAntR As Long
      Dim aR() As Single
      Dim aK() As Single
      Dim n As Integer
      Dim sFil1 As String
      Dim sFil2 As String
      Dim sKat As String
      Dim sArk As String
      Dim sh As Worksheet
      Dim nWb As Workbook
      Dim i As Integer
      i = 1
          sh.Activate
          ReDim aR(lAntR)
          ReDim aK(iAntK)
          For n = 1 To lAntR
          Next n
          For n = 1 To iAntK
          Next n
          Range(sh.Cells(1, 1), sh.Cells(lAntR, iAntK)).Copy
          With nWb
              .Sheets(i).Paste    '([a1])
              For n = 1 To lAntR
              Next n
              For n = 1 To iAntK
              Next n
          i = i + 1
      Dim iVBComponent As Object
      Dim a As Boolean
      With Application
                  a = CopyModule(iVBComponent.Name, _
                     ThisWorkbook.VBProject, _
                     wb.VBProject, True)
Function CopyModule(ModuleName As String, _
                      FromVBProject, _
                      ToVBProject, _
                      OverwriteExisting As Boolean) As Boolean
      Dim VBComp   As Object 'As VBIDE.VBComponent
      Dim FName$, CompName$, S$
      Dim SlashPos&, ExtPos&
      Dim TempVBComp    'As VBIDE.VBComponent
      Dim vbext_pp_locked As Boolean
      On Error Resume Next
      Set VBComp = FromVBProject.VBComponents(ModuleName)
      If Err.Number <> 0 Then
          CopyModule = False
          Exit Function
      FName = Environ("Temp") & "\" & ModuleName & ".bas"
      If OverwriteExisting = True Then
          If Dir(FName, vbNormal + vbHidden + vbSystem) <> vbNullString Then
              Err.Clear
              Kill FName
                  CopyModule = False
                  Exit Function
          With ToVBProject.VBComponents
              .Remove .Item(ModuleName)
      Else
          Err.Clear
          Set VBComp = ToVBProject.VBComponents(ModuleName)
              If Err.Number = 9 Then
                  ' module doesn't exist. ignore error.
              Else
                  ' other error. get out with return value of False
                  CopyModule = False
                  Exit Function
      FromVBProject.VBComponents(ModuleName).Export Filename:=FName
      SlashPos = InStrRev(FName, "\")
      ExtPos = InStrRev(FName, ".")
      CompName = Mid(FName, SlashPos + 1, ExtPos - SlashPos - 1)
      Set VBComp = Nothing
      Set VBComp = ToVBProject.VBComponents(CompName)
      If VBComp Is Nothing Then
          ToVBProject.VBComponents.Import Filename:=FName
      Else
          Set TempVBComp = ToVBProject.VBComponents.Import(FName)
          ' TempVBComp is source module
          With VBComp.CodeModule
              .DeleteLines 1, .CountOfLines
              S = TempVBComp.CodeModule.Lines(1, TempVBComp.CodeModule.CountOfLines)
              .InsertLines 1, S
          On Error GoTo 0
          ToVBProject.VBComponents.Remove TempVBComp
      Kill FName
      CopyModule = True
End Function
Сообщение отредактировал KuklP - Понедельник, 21.02.2011, 13:19
СообщениеВымучил, так работает:
Sub ReduceSize()
      Dim lAntR As Long
      Dim aR() As Single
      Dim aK() As Single
      Dim n As Integer
      Dim sFil1 As String
      Dim sFil2 As String
      Dim sKat As String
      Dim sArk As String
      Dim sh As Worksheet
      Dim nWb As Workbook
      Dim i As Integer
      i = 1
          sh.Activate
          ReDim aR(lAntR)
          ReDim aK(iAntK)
          For n = 1 To lAntR
          Next n
          For n = 1 To iAntK
          Next n
          With nWb
              For n = 1 To lAntR
              Next n
              For n = 1 To iAntK
              Next n
          i = i + 1
      Dim a As Boolean
      With Application
                     wb.VBProject, True)
                      FromVBProject, _
                      ToVBProject, _
          CopyModule = False
          Exit Function
              Err.Clear
              Kill FName
                  CopyModule = False
                  Exit Function
      Else
          Err.Clear
              Else
                  CopyModule = False
                  Exit Function
      Else
              .InsertLines 1, S
          On Error GoTo 0
      Kill FName
      CopyModule = True
End Function
Автор - KuklP
Дата добавления - 21.02.2011 в 12:42
Alex_ST Дата: Понедельник, 21.02.2011, 12:45 | Сообщение № 14
Репутация: 622 ±
А может для модулей листов не импорт делать (ты вроде говоришь, что тогда из модулей листов модули класса получаются?), а тупо по одной в цикле текстом переписывать строки начиная с 1 до CodeModule.CountOfLines?
Хотя тогда даже если мы ОЛЕ-объекты листа и сможем скопировать на новый лист, они, наверное, окажутся связанными со старым модулем листа...
СообщениеА может для модулей листов не импорт делать (ты вроде говоришь, что тогда из модулей листов модули класса получаются?), а тупо по одной в цикле текстом переписывать строки начиная с 1 до CodeModule.CountOfLines?
Дата добавления - 21.02.2011 в 12:45
Alex_ST Дата: Понедельник, 21.02.2011, 12:57 | Сообщение № 15
Репутация: 622 ±
Ну, ты скорописец... Пока я ответ вводил, ты уже новый макрос накатал!
Спасибо. Буду разбираться.
СообщениеНу, ты скорописец... Пока я ответ вводил, ты уже новый макрос накатал!
Дата добавления - 21.02.2011 в 12:57
KuklP Дата: Понедельник, 21.02.2011, 13:17 | Сообщение № 16
Репутация: 486 ±
А кнопки все равно будут ссылаться на старую книгу.
Сообщение отредактировал KuklP - Понедельник, 21.02.2011, 13:20
СообщениеА кнопки все равно будут ссылаться на старую книгу.
Автор - KuklP
Дата добавления - 21.02.2011 в 13:17
Alex_ST Дата: Понедельник, 21.02.2011, 15:26 | Сообщение № 17
Репутация: 622 ±
Серёга, я твой код как всегда малость "полирнул" для ясности и сделал так, чтобы его можно было разместить в Personal.xls Честно признаюсь: в работе с VBProject и VBComponents я плаваю по поверхности, поэтому там почти ничего не менял.
(текст превысил допустимую длину, поэтому попробую приложить в следующем посте)
Ещё недоработку обнаружил: в давно использующихся книгах страницы удаляют/добавляют, переставляют...
Поэтому ПРОГРАММНЫЕ номера страниц идут не по порядку и с пропусками.
А в новой книге новые страницы создаются в цикле For Each по порядку расположения их ярлыков листов в старой, т.е. по индексу. И после создания автоматом получают очередное программное имя. Т.е. если самым левым в старой книге был лист с программным номером 9, то в новой книге копия этого листа будет иметь и индекс и программный номер 1, код на него не экспортируется, а для кода старого листа 9 в новой книге будет создан модуль класса Лист9. Я у Климова на msoffice.nm.ru посмотрел как изменять кодовые имена листов... Не могу никак присобачить к твоему коду. sad
Хорошо бы, наверное, перед началом обработки перенумеровать программные имена (индексы) страниц в старой книге, а уж потом начинать копировать/экспортировать.
Сообщение отредактировал Alex_ST - Понедельник, 21.02.2011, 16:33
СообщениеСерёга, я твой код как всегда малость "полирнул" для ясности и сделал так, чтобы его можно было разместить в Personal.xls Честно признаюсь: в работе с VBProject и VBComponents я плаваю по поверхности, поэтому там почти ничего не менял.
Дата добавления - 21.02.2011 в 15:26
Alex_ST Дата: Понедельник, 21.02.2011, 15:29 | Сообщение № 18
Репутация: 622 ±
Option Explicit
Option Base 1
Sub ReduceSize()
      Dim LastRow As Long
      Dim LastColumn As Integer
      Dim arrRowHeight() As Single
      Dim arrColumnWidth() As Single
      Dim newWbk As Workbook
      Dim oldWbName As String
      Dim newWbName As String
      Dim WbPath As String
      Dim ShtName As String
      Dim Sht As Worksheet
      Dim n As Integer
      Dim i As Integer
      WbPath = ActiveWorkbook.Path   ' запомним путь к старой книге
      Set newWbk = Workbooks.Add   ' создадим новую книгу (она сразу станет ActiveWorkbook)
      For Each Sht In Workbooks(oldWbName).Sheets   ' цикл по всем листам старой книги
         Sht.Activate
         With ActiveSheet
            ShtName = .Name
            LastRow = .Cells.Find(What:="*", SearchOrder:=xlByRows, SearchDirection:=xlPrevious).Row   ' последняя строка на листе, содержащая хоть какие-нибудь значения
            LastColumn = .Cells.Find(What:="*", SearchOrder:=xlByColumns, SearchDirection:=xlPrevious).Column   ' последний столбец на листе, содержащий хоть какие-нибудь значения
            ReDim arrRowHeight(LastRow)
            ReDim arrColumnWidth(LastColumn)
               arrRowHeight(n) = .Rows(n).RowHeight
            Next n
               arrColumnWidth(n) = .Columns(n).ColumnWidth
            Next n
            Range(.Cells(1, 1), .Cells(LastRow, LastColumn)).Copy   ' копируем только диапазон, содержащий данные
         With Workbooks(newWbName)
            .Sheets(i).Name = ShtName
            .Sheets(i).Paste   ' копируем на страницу новой книги диапазон, содержащий данные
               .Sheets(i).Rows(n).RowHeight = arrRowHeight(n)
            Next n
               .Sheets(i).Columns(n).ColumnWidth = arrColumnWidth(n)
            Next n
      Call ExportAllStdModules(newWbk, Workbooks(oldWbName))   ' скопировать все компоненты VBA в новую книгу
      Workbooks(oldWbName).Close savechanges:=True
продолжение следует
Сообщение отредактировал Alex_ST - Понедельник, 21.02.2011, 15:30
Option Explicit
Option Base 1
Sub ReduceSize()
      Dim LastRow As Long
      Dim n As Integer
      Dim i As Integer
         Sht.Activate
         With ActiveSheet
            ShtName = .Name
            Next n
            Next n
            Next n
            Next n
продолжение следует
Дата добавления - 21.02.2011 в 15:29
Alex_ST Дата: Понедельник, 21.02.2011, 15:29 | Сообщение № 19
Репутация: 622 ±
продолжение:
Private Sub ExportAllStdModules(newWbk As Workbook, oldWbk As Workbook)   ' скопировать все компоненты VBA в новую книгу
      Dim a As Boolean
      With Application
         With newWbk.VBProject.VBComponents
            For Each iVBComponent In oldWbk.VBProject.VBComponents
                    oldWbk.VBProject, _
                    newWbk.VBProject, True)
                       FromVBProject, _
                       ToVBProject, _
         CopyModule = False
         Exit Function
            Err.Clear
            Kill FName
               CopyModule = False
               Exit Function
      Else
         Err.Clear
            Else
               CopyModule = False
               Exit Function
      FromVBProject.VBComponents(ModuleName).Export FileName:=FName
         ToVBProject.VBComponents.Import FileName:=FName
      Else
            .InsertLines 1, S
         On Error GoTo 0
      Kill FName
      CopyModule = True
End Function
Сообщениепродолжение:
      Dim a As Boolean
      With Application
                    oldWbk.VBProject, _
                       FromVBProject, _
                       ToVBProject, _
         CopyModule = False
         Exit Function
            Err.Clear
            Kill FName
               CopyModule = False
               Exit Function
      Else
         Err.Clear
            Else
               CopyModule = False
               Exit Function
      Else
            .InsertLines 1, S
         On Error GoTo 0
      Kill FName
      CopyModule = True
End Function
KuklP Дата: Понедельник, 21.02.2011, 17:10 | Сообщение № 20
Репутация: 486 ±
Public Sub www()
Dim Sh As Object, iCodeName$
For Each Sh In Sheets
iCodeName = Sh.CodeName
Application.VBE.ActiveVBProject.VBComponents(iCodeName).Name = Sh.Name
Сообщение отредактировал KuklP - Понедельник, 21.02.2011, 17:37
Public Sub www()
Автор - KuklP
Дата добавления - 21.02.2011 в 17:10
  • Страница 1 из 5
  • 4
  • 5
