bohdankokhan
Дата: Понедельник, 10.01.2022, 17:23 |
Добрый день! Нужно чтобы информация которая заполняется с формы дублировалась на другую таблицу что находится на другом листе. Код кнопки "Записать":
Private Sub CommandButton1_Click() Dim f As Boolean If IsDate(txtFillingTime.Value) = False Then MsgBox "Введите время согласно шаблону ЧЧ:ММ" Exit Sub End If Dim c, i For Each c In Me.Controls If TypeName(c) = "TextBox" Then If c.name <> "TxtComment" Then If c.Value = "" Then MsgBox "Заполните все поля!" Exit Sub End If End If End If Next c Dim yeast, filtrationFlow, BBTNumber, consumptionPVPP, consumptionDE, posStr As Integer Dim pressureEntranceS, pressureEntranceE, Turbidity25, Turbidity90, pressureDifTrap, Density, pressureEntrance As Double Dim beerGrade, fillingTime, typeOfCapacity, comment As String beerGrade = ComboBox1.Text yeast = txtYeast.Value Density = TextBox_Density pressureEntranceS = txtPressureEntrance.Value pressureEntranceE = TextBox1.Value pressureEntrance = pressureEntranceS - pressureEntranceE Turbidity25 = txtTurbidity25.Value Turbidity90 = txtTurbidity90.Value consumptionPVPP = txtConsumptionPVPP.Value consumptionDE = txtConsumptionDE.Value filtrationFlow = TextBox2.Value BBTNumber = txtBBTNumber.Value pressureDifTrap = txtPressureDifTrap.Value fillingTime = txtFillingTime.Value If TxtComment = "Комментарий" Then comment = "" Else comment = TxtComment End If If optCCT.Value = True Then typeOfCapacity = "ЦКТ" Else typeOfCapacity = "Лагерный танк" End If posStr = Cells(Rows.Count, 2).End(xlUp).Row + 1 Cells(posStr, "B") = beerGrade Cells(posStr, "C") = fillingTime Cells(posStr, "D") = DatePart("h", Time) & ":" & DatePart("n", Time) Cells(posStr, "E") = typeOfCapacity Cells(posStr, "G") = txtNumber.Value Cells(posStr, "H") = yeast Cells(posStr, "I") = Density Cells(posStr, "J") = pressureEntranceS Cells(posStr, "K") = pressureEntranceE Cells(posStr, "L") = pressureEntrance Cells(posStr, "N") = Turbidity25 Cells(posStr, "P") = Turbidity90 Cells(posStr, "Q") = consumptionPVPP Cells(posStr, "R") = consumptionDE Cells(posStr, "S") = filtrationFlow Cells(posStr, "T") = BBTNumber Cells(posStr, "U") = pressureDifTrap Cells(posStr, "V") = comment Dim Lastrow As Long, str As String Dim Dict As Object, key, item, j, k, arr() Set Dict = CreateObject("Scripting.Dictionary") Lastrow = Cells(Rows.Count, 2).End(xlUp).Row For j = 19 To Lastrow - 1 key = Cells(j, 5) & " " & Cells(j, 7) If Not Dict.exists(key) Then Dict.Add key, Array(Cells(j, 2), Cells(j, 5), Cells(j, 7), Cells(j, 9)) Next j ReDim arr(1 To 4) arr(1) = beerGrade arr(2) = typeOfCapacity arr(3) = txtNumber.Value arr(4) = Density str = typeOfCapacity & " " & txtNumber.Value If Not Dict.exists(str) Then Lastrow = Cells(Rows.Count, 28).End(xlUp).Row If IsEmpty(Cells(19, 28)) Then Cells(Lastrow + 1, 28).Resize(1, UBound(arr)) = arr Else Lastrow = Cells(Rows.Count, 28).End(xlUp).Row Cells(Lastrow + 1, 28).Resize(1, UBound(arr)) = arr End If End If [color=red]'Дублирование данных VBA[/color] posStr = Sheets("База данных").Cells(Rows.Count, 2).End(xlUp).Row + 1 Cells(posStr, "A") = Range("D10") Cells(posStr, "B") = Range("D11") Cells(posStr, "C") = beerGrade Cells(posStr, "D") = fillingTime Cells(posStr, "E") = DatePart("h", Time) & ":" & DatePart("n", Time) Cells(posStr, "F") = typeOfCapacity Cells(posStr, "G") = txtNumber.Value Cells(posStr, "H") = yeast Cells(posStr, "I") = Density Cells(posStr, "J") = pressureEntranceS Cells(posStr, "K") = pressureEntranceE Cells(posStr, "L") = pressureEntrance Cells(posStr, "M") = Turbidity25 Cells(posStr, "N") = Turbidity90 Cells(posStr, "O") = consumptionPVPP Cells(posStr, "P") = consumptionDE Cells(posStr, "Q") = filtrationFlow Cells(posStr, "R") = BBTNumber Cells(posStr, "S") = pressureDifTrap Cells(posStr, "T") = comment Unload Me End Sub
bohdankokhan
Сообщение отредактировал Serge_007 - Понедельник, 10.01.2022, 17:38
Сообщение Добрый день! Нужно чтобы информация которая заполняется с формы дублировалась на другую таблицу что находится на другом листе. Код кнопки "Записать":
Автор - bohdankokhan Дата добавления - 10.01.2022 в 17:23
