ВАЖНЫЕ ОБЪЯВЛЕНИЯ:
= Мир MS Excel/it is ridiculous trying to remove multiple duplicates but do - Мир MS Excel
corriedtoppin Дата: Понедельник, 19.04.2021, 17:41 | Сообщение № 1
Hello Supporters
I have a concern. Below I have an example of a sample file with multiple phone numbers.
I tried using: Data tab >> Remove duplicates.
But for some reason it doesn't work out
How can I use the VBA to help fix this problem?
How can the VBA scan and delete any future data that may have duplicates?
Thanks in advance
Cheers
К сообщению приложен файл: Remove_Duplicat.xlsx (22.9 Kb)
СообщениеHello Supporters
Thanks in advance
Cheers
Автор - corriedtoppin
Дата добавления - 19.04.2021 в 17:41
NikitaDvorets Дата: Понедельник, 19.04.2021, 17:57 | Сообщение № 2
Репутация: 148 ±
Greetings, corriedtoppin,
For reference:
https://www.automateexcel.com/vba....cel-vba
СообщениеGreetings, corriedtoppin,
For reference:
Автор - NikitaDvorets
Дата добавления - 19.04.2021 в 17:57
corriedtoppin Дата: Понедельник, 19.04.2021, 19:22 | Сообщение № 3
Thank you NikitaDvorets,
It seems like I am stuck. It looks like this problem is out of my hands.
I have followed the link and your tuition.
The problem here is this: for some reason. The phone numbers, not deleting.
For example. I have three of the same phone numbers on column A, B & C in row #1.
365-1897 365-1897 365-1897
The vba is not deleting any. A matter a fact, when I search for the number on "Find and replace box" it selects two numbers out of three.
I am not sure if the numbers are formatted or something.
What do you suggest I do from here?
How can I overcome this problem?
Thanks in advance
СообщениеThank you NikitaDvorets,
Thanks in advance
Дата добавления - 19.04.2021 в 19:22
NikitaDvorets Дата: Вторник, 20.04.2021, 00:24 | Сообщение № 4
Репутация: 148 ±
Greeting again. corriedtoppin,
The problem is - deleting dupes in multiple columns.
I suggest that the most simple way - is to use conditional formatting (see "Phones - test" in the attached file).
1. Select first three columns.
2. Use conditional formatting to point the repeated cells with the color.
3. Use autofilter with the option "color filter"
4. Finally you select only coloured cells and delete them.
See also:
https://marcus-small.squarespace.com/blog....columns
Regards.
К сообщению приложен файл: Remove_duplicat.xlsm (39.8 Kb)
Сообщение отредактировал NikitaDvorets - Вторник, 20.04.2021, 00:26
СообщениеGreeting again. corriedtoppin,
See also:
Regards.
Дата добавления - 20.04.2021 в 00:24
corriedtoppin Дата: Вторник, 20.04.2021, 03:39 | Сообщение № 5
NikitaDvorets
Thanks for your feedback. Really appreciate sour support...
conditional formatting really did the trick.
Learn something new.
Thank you for helping me with my problem.
Greatly appreciated
Cheers
СообщениеNikitaDvorets
Greatly appreciated
Cheers
Дата добавления - 20.04.2021 в 03:39
Pelena Дата: Вторник, 20.04.2021, 09:35 | Сообщение № 6
Репутация: 4721 ±
[offtop] NikitaDvorets, Никита, respect :) [/offtop]
Сообщение[offtop] NikitaDvorets, Никита, respect :) [/offtop]
Дата добавления - 20.04.2021 в 09:35
