AVI
Дата: Четверг, 20.10.2016, 16:07 |
Добрый день! Средствами записи макроса я записал вот такого монстра. [vba]Код
Sub Макрос5() Application.CutCopyMode = False Cells.Replace What:="ул., д.", Replacement:="", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:="пер., д.", Replacement:="", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:="мкр., д.", Replacement:="", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:="пр-кт., д.", Replacement:="", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:="бул., д.", Replacement:="", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:=", кв.", Replacement:="", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:="просп., д.", Replacement:="", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:="комнаты", Replacement:="к.", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:="комната", Replacement:="к.", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:="комн", Replacement:="к.", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:="ком", Replacement:="к.", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:=", к.", Replacement:="к.", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:=",к.", Replacement:="к.", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False Cells.Replace What:=" ", Replacement:=" ", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False End Sub
[/vba] Все бы ничего но, помогите, пожалуйста сделать так, что бы он работал только, например, по столбцу а. И помогите заставить его выполнять такую функциюКод
ПСТР(A2;1;(НАЙТИ(".";A2;1)-1))&ПОДСТАВИТЬ(ПСТР(A2;ПОИСК(".";A2);99);"-";"")
Смысл ее в том, что в первоначально в тексте она удаляет тире "-" после первой точки, а уж потом выполняется то, что описано выше.
Смысл ее в том, что в первоначально в тексте она удаляет тире "-" после первой точки, а уж потом выполняется то, что описано выше. AVI
Сообщение Добрый день! Средствами записи макроса я записал вот такого монстра. [vba]Код
Смысл ее в том, что в первоначально в тексте она удаляет тире "-" после первой точки, а уж потом выполняется то, что описано выше. Автор - AVI Дата добавления - 20.10.2016 в 16:07
Karataev
Дата: Четверг, 20.10.2016, 16:29 |
Excel
Чтобы вести замену только в столбце "A" замените "Cells" на Columns("A"): [vba]Код
Columns("A").Replace What:="ул., д.", Replacement:="", LookAt:=xlPart, _ SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _ ReplaceFormat:=False
[/vba] Макрос для удаления дефисов: [vba]Код
Sub Удалить_дефисы() Dim arr(), lngInStr As Long, lr As Long, i As Long lr = Columns("A").Find(What:="*", LookIn:=xlFormulas, LookAt:= _ xlPart, SearchOrder:=xlByRows, SearchDirection:=xlPrevious, MatchCase:=False _ , SearchFormat:=False).Row arr() = Range("A1:A" & lr).Value For i = 2 To UBound(arr) lngInStr = InStr(arr(i, 1), ".") If lngInStr > 0 Then arr(i, 1) = Left(arr(i, 1), lngInStr - 1) & Replace(arr(i, 1), "-", "", lngInStr) Else arr(i, 1) = Replace(arr(i, 1), "-", "") End If Next Range("A1:A" & lr).Value = arr() End Sub
[/vba] Karataev
Сообщение отредактировал Karataev - Четверг, 20.10.2016, 16:30
Сообщение Чтобы вести замену только в столбце "A" замените "Cells" на Columns("A"): [vba]Код
[/vba] Автор - Karataev Дата добавления - 20.10.2016 в 16:29
