350 |
Дата: Вторник, 12.12.2023, 13:30 |
Сообщение № 1 |
Уважаемые знатоки Excel, добрый день!
Помогите, пожалуйста, превратить первую таблицу во вторую, используя именно Power Query.
Заранее благодарю!
Заранее благодарю!350
Сообщение отредактировал Serge_007 - Вторник, 12.12.2023, 21:28 |
| Ответить
jakim |
Дата: Вторник, 12.12.2023, 17:36 |
Сообщение № 2 |
Excel 2010 | |
Power Query l[vba]Код et Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content], #"Changed Type" = Table.TransformColumnTypes(Source,{{"Наименование", type text}, {"Месяцы", type any}, {"Column1", type any}, {"Column2", type any}, {"Column3", type any}, {"Column4", type any}, {"Column5", type any}, {"Column6", type any}, {"Column7", type any}}), #"Promoted Headers" = Table.PromoteHeaders(#"Changed Type", [PromoteAllScalars=true]), #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Promoted Headers", {"Column1"}, "Месяц", "Значение"), #"Removed Top Rows" = Table.Skip(#"Unpivoted Other Columns",8), #"Added Index" = Table.AddIndexColumn(#"Removed Top Rows", "Index", 0, 1), #"Inserted Modulo" = Table.AddColumn(#"Added Index", "Modulo", each Number.Mod([Index], 2), type number), #"Added Conditional Column" = Table.AddColumn(#"Inserted Modulo", "план/факт", each if [Modulo] = 0 then "план" else if [Modulo] = 1 then "факт" else null), #"Split Column by Delimiter" = Table.SplitColumn(#"Added Conditional Column", "Месяц", Splitter.SplitTextByEachDelimiter({"_"}, QuoteStyle.Csv, false), {"Месяц.1", "Месяц.2"}), #"Removed Other Columns" = Table.SelectColumns(#"Split Column by Delimiter",{"Column1", "Месяц.1", "план/факт", "Значение"}), #"Renamed Columns" = Table.RenameColumns(#"Removed Other Columns",{{"Column1", "Наименование"}, {"Месяц.1", "Месяц"}}), #"Filtered Rows" = Table.SelectRows(#"Renamed Columns", each ([Месяц] <> "Итого")) in #"Filtered Rows" [/vba]
Power Query l[vba]Код et Source = Excel.CurrentWorkbook(){[Name="Table1"]}[Content], #"Changed Type" = Table.TransformColumnTypes(Source,{{"Наименование", type text}, {"Месяцы", type any}, {"Column1", type any}, {"Column2", type any}, {"Column3", type any}, {"Column4", type any}, {"Column5", type any}, {"Column6", type any}, {"Column7", type any}}), #"Promoted Headers" = Table.PromoteHeaders(#"Changed Type", [PromoteAllScalars=true]), #"Unpivoted Other Columns" = Table.UnpivotOtherColumns(#"Promoted Headers", {"Column1"}, "Месяц", "Значение"), #"Removed Top Rows" = Table.Skip(#"Unpivoted Other Columns",8), #"Added Index" = Table.AddIndexColumn(#"Removed Top Rows", "Index", 0, 1), #"Inserted Modulo" = Table.AddColumn(#"Added Index", "Modulo", each Number.Mod([Index], 2), type number), #"Added Conditional Column" = Table.AddColumn(#"Inserted Modulo", "план/факт", each if [Modulo] = 0 then "план" else if [Modulo] = 1 then "факт" else null), #"Split Column by Delimiter" = Table.SplitColumn(#"Added Conditional Column", "Месяц", Splitter.SplitTextByEachDelimiter({"_"}, QuoteStyle.Csv, false), {"Месяц.1", "Месяц.2"}), #"Removed Other Columns" = Table.SelectColumns(#"Split Column by Delimiter",{"Column1", "Месяц.1", "план/факт", "Значение"}), #"Renamed Columns" = Table.RenameColumns(#"Removed Other Columns",{{"Column1", "Наименование"}, {"Месяц.1", "Месяц"}}), #"Filtered Rows" = Table.SelectRows(#"Renamed Columns", each ([Месяц] <> "Итого")) in #"Filtered Rows" [/vba]jakim
| Ответить
