= Мир MS Excel/Заполнить google sheets данными из excel, при помощи vba - Страница 2 - Мир MS Excel
  • Страница 2 из 2
airatgimranoff Дата: Вторник, 13.06.2023, 18:52 | Сообщение № 21
TvoiExcel,
VBA часть:
Sub sendPOST()
Const webAppId As String = "********" 'Id веб-приложения, доступного всем после авторизации
Dim httpRequest As Object 'MSXML2.XMLHTTP
Dim URL As String
Dim requestBody As Variant
Dim row As Integer, col As Integer
Dim rng As Range
Set rng = ActiveSheet.Range(Cells(1, 1), Cells(23, 14)) 'выбираем любой диапазон на активном листе
Dim content as String
content = ToArrJSON(rng)
requestBody = "&content=" & EncodeUriComponent(content)
URL = "https://script.google.com/macros/s/" & webAppId & "/exec"
Set httpRequest = CreateObject("MSXML2.XMLHTTP")
httpRequest.Open "POST", URL, False
httpRequest.setRequestHeader "Content-Type", "application/x-www-form-urlencoded"
httpRequest.Send requestBody
Set httpRequest = Nothing
'конвертируем Кириллицу
Public Function EncodeUriComponent(str)
Static objHtmlfile As Object
If objHtmlfile Is Nothing Then
Set objHtmlfile = CreateObject("htmlfile")
objHtmlfile.parentWindow.execScript "function encode(s) {return encodeURIComponent(s)}", "jscript"
EncodeUriComponent = objHtmlfile.parentWindow.encode(str)
End Function
'заворачиваем данные из диапазона rng в JSON
Public Function ToArrJSON(rng As Range) As String
' Make sure there are two columns in the range
If rng.Columns.Count < 2 Then
ToArrJSON = CVErr(xlErrNA)
Exit Function
Dim dataLoop, headerLoop As Long
' Get the first row of the range as a header range
Dim headerRange As Range: Set headerRange = Range(rng.Rows(1).Address)
Dim colCount As Long: colCount = headerRange.Columns.Count
Dim json As String: json = "["
For dataLoop = 0 To rng.Rows.Count
' Include the first header row as well
If dataLoop > 0 Then
' Start data row
Dim rowJson As String: rowJson = "["
For headerLoop = 1 To colCount
rowJson = rowJson & """" & rng.Value2(dataLoop, headerLoop) & """"
rowJson = rowJson & ","
Next headerLoop
' Strip out the last comma
rowJson = Left(rowJson, Len(rowJson) - 1)
' End data row
json = json & rowJson & "],"
json = Left(json, Len(json) - 1)
json = json & "]"
ToArrJSON = json
End Function
Google Script часть:
function doPost(e) {
let ss = SpreadsheetApp.openById('************'); //id файла
let sheet = ss.getSheetByName('*******');//имя листа
let content = e.parameter.content;
let parsedContent = JSON.parse(content);
let ResultArray = [parsedContent[0].slice()];
for (let i=1; i<parsedContent.length; i++) {
ResultArray.push( parsedContent[i].slice() )
let needRows = ResultArray.length;
let needCols = ResultArray[0].length;
sheet.getRange(1, 1, needRows, needCols).setValues(ResultArray)
Сохраняем. Делаем развёртывание. У меня всё работает. Присваиваем в VBA переменной webAppId нужный адрес Вэб-Приложения (после развёртывания копируем с экрана) .
В прикреплённом скрине все подключения, которые у меня есть в Tools => References =>
К сообщению приложен файл: 4872605.png (123.0 Kb)
Сообщение отредактировал Serge_007 - Среда, 14.06.2023, 09:34
СообщениеTvoiExcel,
VBA часть:
Sub sendPOST()
Dim URL As String
Dim rng As Range
End Function
Exit Function
' Start data row
Next headerLoop
' End data row
json = json & "]"
ToArrJSON = json
End Function
Автор - airatgimranoff
Дата добавления - 13.06.2023 в 18:52
  • Страница 2 из 2
