= Мир MS Excel/Найти текст и при его наличии вывести название файла - Мир MS Excel
ant6729 Дата: Среда, 09.01.2019, 22:43 | Сообщение № 1
Репутация: 2 ±
Замечаний: 40% ±
Всем привет, ищу определенный текст в большом количестве текстовых файлов, и название файла, содержащего этот текст
Ищу примерно так.
Option Explicit
Dim fsoFile As file, fsoFolder As Folder
Dim key As Variant
Dim dict As Scripting.Dictionary
Sub You()
    'Dim fsoFile As file, fsoFolder As Folder
    Dim ReportFile
    Dim fso As New FileSystemObject
    Dim Spath, StrFile, lr, fj, Sal
    Spath = Application.ThisWorkbook.Path & "\"
    Set fsoFolder = fso.GetFolder(Spath)
    Set dict = New Scripting.Dictionary
    For Each fsoFile In fsoFolder.Files
        If fsoFile Like "*.txt" Then Call sort
    Next fsoFile
    SortDictionary dict
    With dict
        For Each key In .Keys
        'For key = 1 To 5
            Debug.Print key, .Item(key)
    Range("A1").Resize(, 2) = Array("Values", ".txtName")
'    Range("A2").Resize(5) = Application.Transpose(.Keys)
'    Range("B2").Resize(5) = Application.Transpose(.Items)
    Range("A2").Resize(.Count) = Application.Transpose(.Keys)
    Range("B2").Resize(.Count) = Application.Transpose(.Items)
    '[a1].sort Key1:=[a1], Order1:=xlAscending, Header:=xlYes
    'fj = Application.Max(.Keys)
    lr = Cells(Rows.Count, "A").End(xlUp).Row
    'Sal = Application.WorksheetFunction.VLookup(fj, Range("A2:B" & lr), 2, False)
    'MsgBox "Ìàêñèìàëüíîå çíà÷åíèå ñðåäè ôàéëîâ:" & vbNewLine & Application.Max(.Keys) & " â " & Sal
Sub sort()
        Open fsoFile For Input As #1
        Dim s As String
        Dim m, k
        While Not EOF(1)
            Input #1, s
            On Error Resume Next
            m = (CatchNum(s))
            'm = Int(Left(s, 10))
            'm = Split((Split(s, " ")(0)), ",")(1)
            'm = Int(Left(Split(s, ",")(1), 3))
            dict.Add m, fsoFile.Name
        Wend
        Close #1
Sub SortDictionary(dict As Object)
    Dim i As Long
    With CreateObject("System.Collections.SortedList")
        For Each key In dict
            .Add key, dict(key)
        dict.RemoveAll
        For i = 0 To .Keys.Count - 1
            dict.Add .GetKey(i), .Item(.GetKey(i))
Function CatchNum(s As String) As Long
    Dim objRegExp, SubobjMatches
        Set objRegExp = CreateObject("VBScript.RegExp")
        objRegExp.Global = True
        objRegExp.Pattern = "1037604"
        'objRegExp.Pattern = "[^,]+,([\d]+)"
        Set SubobjMatches = objRegExp.Execute(s)
        CatchNum = SubobjMatches(0).Value
End Function
Но это мертвая процедура
Файлов бывает 300 штук, каждый по 5 кб txt Строк может быть и 20000
Есть ли возможности оптимизации?
Если раньше искал по паттерну, то теперь просто хочу найти по значению.
В принципе, могу просто убрать процедуру с регулярными выражениями. Но насколько это ускорит, не знаю.
Хотелось бы услышать и увидеть варианты оптимизации для этой задачи на Excel.
Неужели Excel не подходит для больших данных...
К сообщению приложен файл: Script_example.xlsb (20.0 Kb)
СообщениеВсем привет, ищу определенный текст в большом количестве текстовых файлов, и название файла, содержащего этот текст
Ищу примерно так.
Option Explicit
Dim key As Variant
Sub You()
    Dim ReportFile
    Next fsoFile
    SortDictionary dict
    With dict
        'For key = 1 To 5
Sub sort()
        Dim s As String
        Dim m, k
        While Not EOF(1)
            Input #1, s
            m = (CatchNum(s))
        Wend
        Close #1
    Dim i As Long
            .Add key, dict(key)
        dict.RemoveAll
End Function
Автор - ant6729
Дата добавления - 09.01.2019 в 22:43
vikttur Дата: Среда, 09.01.2019, 23:16 | Сообщение № 2
Репутация: 526 ±
Без обратной связи помогать - как в стенку... Подошло, не подошло, подправить, пожелания... Вы в своих темах отписываться думаете?
Сообщение отредактировал vikttur - Среда, 09.01.2019, 23:20
СообщениеБез обратной связи помогать - как в стенку... Подошло, не подошло, подправить, пожелания... Вы в своих темах отписываться думаете?
Автор - vikttur
Дата добавления - 09.01.2019 в 23:16
ant6729 Дата: Среда, 09.01.2019, 23:24 | Сообщение № 3
Репутация: 2 ±
Замечаний: 40% ±
Ну, конечно, собираюсь)
СообщениеНу, конечно, собираюсь)
Автор - ant6729
Дата добавления - 09.01.2019 в 23:24
