vanderlord
Дата: Среда, 28.11.2018, 14:33 |
Добрый день. Нужна помощь в автоматизации макроса для подсчёта статистических данных. Делаю статистику для любительских лиг по футзалу, необходимо подсчитать повторение забитых и пропущенных мячей командой. Взято пять игр, повторения равны 0,1,2,>2. [vba]Код
Sub Макрос1() ' Макрос1 Макрос Sheets.Add After:=Sheets(Sheets.Count) Columns("B:B").ColumnWidth = 25.5 Range("D1").Select ActiveCell.FormulaR1C1 = "Win A" Range("E1").Select ActiveCell.FormulaR1C1 = "Lost B" Range("F1").Select ActiveCell.FormulaR1C1 = "Win B" Range("G1").Select ActiveCell.FormulaR1C1 = "Lost A" ' 1-ый Range("A2").Select ActiveCell.FormulaR1C1 = "=А!R[2]C" Range("B2").Select ActiveCell.FormulaR1C1 = "=CONCATENATE(А!R[2]C[2],"" -"",Б!R[2]C[2])" Range("D2").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[1]C[1]:R[5]C[1],""=0"")" Range("D3").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!RC[1]:R[4]C[1],""=1"")" Range("D4").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[-1]C[1]:R[3]C[1],""=2"")" Range("D5").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[-2]C[1]:R[2]C[1],"">2"")" Range("E2").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[1]C[1]:R[5]C[1],""=0"")" Range("E3").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!RC[1]:R[4]C[1],""=1"")" Range("E4").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[-1]C[1]:R[3]C[1],""=2"")" Range("E5").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[-2]C[1]:R[2]C[1],"">2"")" Range("F2").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[1]C[-1]:R[5]C[-1],""=0"")" Range("F3").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!RC[-1]:R[4]C[-1],""=1"")" Range("F4").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[-1]C[-1]:R[3]C[-1],""=2"")" Range("F5").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[-2]C[-1]:R[2]C[-1],"">2"")" Range("G2").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[1]C[-1]:R[5]C[-1],""=0"")" Range("G3").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!RC[-1]:R[4]C[-1],""=1"")" Range("G4").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[-1]C[-1]:R[3]C[-1],""=2"")" Range("G5").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[-2]C[-1]:R[2]C[-1],"">2"")" ' 2-ой Range("A6").Select ActiveCell.FormulaR1C1 = "=А!R[2]C" Range("B6").Select ActiveCell.FormulaR1C1 = "=CONCATENATE(А!R[2]C[2],"" - "",Б!R[2]C[2])" Range("B7").Select Range("D6").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[2]C[1]:R[6]C[1],""=0"")" Range("D7").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[1]C[1]:R[5]C[1],""=1"")" Range("D8").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!RC[1]:R[4]C[1],""=2"")" Range("D9").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[-1]C[1]:R[3]C[1],"">2"")" Range("E6").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[2]C[1]:R[6]C[1],""=0"")" Range("E7").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[1]C[1]:R[5]C[1],""=1"")" Range("E8").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!RC[1]:R[4]C[1],""=2"")" Range("E9").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[-1]C[1]:R[3]C[1],"">2"")" Range("F6").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[2]C[-1]:R[6]C[-1],""=0"")" Range("F7").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[1]C[-1]:R[5]C[-1],""=1"")" Range("F8").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!RC[-1]:R[4]C[-1],""=2"")" Range("F9").Select ActiveCell.FormulaR1C1 = "=COUNTIF(Б!R[-1]C[-1]:R[3]C[-1],"">2"")" Range("G6").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[2]C[-1]:R[6]C[-1],""=0"")" Range("G7").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[1]C[-1]:R[5]C[-1],""=1"")" Range("G8").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!RC[-1]:R[4]C[-1],""=2"")" Range("G9").Select ActiveCell.FormulaR1C1 = "=COUNTIF(А!R[-1]C[-1]:R[3]C[-1],"">2"")" End Sub
[/vba] vanderlord
Сообщение отредактировал vanderlord - Среда, 28.11.2018, 14:35
Сообщение Добрый день. Нужна помощь в автоматизации макроса для подсчёта статистических данных. Делаю статистику для любительских лиг по футзалу, необходимо подсчитать повторение забитых и пропущенных мячей командой. Взято пять игр, повторения равны 0,1,2,>2. [vba]Код
[/vba] Автор - vanderlord Дата добавления - 28.11.2018 в 14:33
